Lines Aft with SpinLock XAS Clutch & ViadanaUsa Deck Organizers Lines Led Aft
- Boat Type: Lines Led Aft, MacGregor 26X, Boat Type
I've finally run my lines aft to the cockpit using SpinLock XAS Roap clutches and Viadana deck organizers. I'm also using the BWYacth mast deck plate. I picked up the Rope Clutches on sale over the past yr and recently came across the Viadana sailing company looking for Deck Organizers. They're much less than the normal brands, but seem to be of good quality. I had some challenging finding metric screws to mount them (it takes 6mm, not 1/4") and their support was fantastic and found 6Mx70mm Screws and had them shipped to me free of charge.
I ran the mainsail and downhaul on the Starboard side and Vang (I have a boom kicker) on the port side so have an extra spot on both sides if I need more.
I struggled with where to put them so they lined up internally and externally. Overall happy with it and now I can raise/lower my sails without having to leave the cockpit.
Still have to clean up to do, but here is the work in progress
Related Mods
Correct Mast Raising Stay DesignRigging - MRS (MacGregor 26M) - January 30, 2020
The 26M raising stays are not connected to the mast. This is easily rectified by connecting the stays at the mast raising bail. The problem is, the stanchion connection is not in line with the hinge pin at the mast step bracket. In this mod, I reloca...
Quick Release PinsRigging - - December 1, 2019
We all hate to mess with clevis pins right? Try ball lock pins. I use 1/4 " x 2" pins on the boom/mast gooseneck connection, the tack of the main, and to fasten the roller reefing drum to the bow. Never had one come loose but I recommned using long p...
sail packRigging - - January 7, 2018
Sail pack kit from Sailrite, and self made lazy jack system. Published by: bobflshmn
