3D Printed West Marine Panel od
- Boat Type: MacGregor 26X, Boat Type
I have three West Marine power panels in my 26x right now. I had only one small 4-switch one initially, but my system and needs have grown with my recent revising of the electrical system. I have an issue with these simple and inexpensive panels. Older eyes can’t read 6 to 8 point type in some variant of Helvetica thin. To rectify this I used a label maker on the first one years ago. That was OK until several Summers got to it and the labels are curling. Hmmm, it’s time to King-Kong this.
Revision 1: I started by coming up with a 3d-printed label, but it would have to be glued or screw fastened from the rear as a semi practical solution. Glue was permanent and screws can get loose and wreak electrical havoc. I observed these possibilities after making one as a test. Fussy and sloppy.
Revision 2: So I doodled up something that would sit over the panel and hold labels. Cute, but overly complicated.
Revision 3: Then it dawned on me that I could use the West Marine Carling switches and bus bars in an entirely new 3D printed panel. And that is what I did. You can print a panel in any color, it is non-conductive and you can use ABS as the polymer. Labels can be plastic inserts and hence changeable in color and content, moreover the letters can be multi-lingual and LARGE. about .3 inches is very legible from the cabin and deck. I chose to make this one the exact size of the West Marine unit with a mild swale at the screw mounts to get enhanced performance from the FDM part.
How was it made? 3 hours with my nose in Fusion 360 to gin up a part (a CAD package),10 minutes in a slicer program (writes posts in G-code for a specific 3D printer) then 12 hours on a Printer (Prusa Mk3i). For the first panel I had to make three in total. The first print had settings that were not optimal and the part failed. The next two went well, one in black and one in blue. I favored the blue with black labels and luminescent green letters that show white but glow in the dark. See enclosed pictures.
Related Mods
Shore Power 120v AC panel 26MElectrical - Shore power (MacGregor 26M) - May 21, 2020
Marinco Stainless inlet, Blue Sea Systems AC Panel 8101 and outlets on a 2007 26M The key to successful inlet placement when you have to cut the Large hole in the boat was to cut the panel hole first, remove all foam, make a template of the inlet siz...
Electrical outlet near the dinetteElectrical - (MacGregor 26X) - December 1, 2019
A power outlet in the corner headroom/aft dinett seat/hull for mobile phone and everything else you might use while sitting by the dinett. Published by: MS Classifieds
Solar panelsElectrical - - December 1, 2019
I installed 2 SOLAREX MSX 30 LITE solar panels on the hatch. They fit perfectly and leave enough space on each side for a teak grab rail in the future. Right now the panels are oversized (from the power point of view) since I do not have any big cons...
