Mac 26X Hatchway Screens
- Boat Type: MacGregor 26X, Boat Type
Made some ventilation/bug hatchway screens.
I believe this material is used for making RV screen porches. Also looks similar to what is sold at Home Depot or Lowe's in garden section for greenhouses. (Which all means I don't remember who gave it to me for free.)
Measured and cut for a 1" seam all around ea. piece. Sewed by hand using 4 lb. test fishing line ('cause it's what I had.)
Hatch screen has 6 button snaps (from any hardware store) along the hatch rails (3 on ea. side) that just screw in after drilling guide holes. (Hatch slides easily past these.)
The screen at the doorway has 2 of these snaps at the top and a flexible piece of thick plastic across the bottom that holds the material in the grooves from top to bottom. (The original big, white one-piece door will still fit past these snaps if used.)
Front hatch had a card board template made then flattened out on the netting and cut in one piece... then folded where needed and sewn. I pushed a small but heavy chain through the entire lower hem that lays nicely in the groove around the hatchway.
More details/pics upon request.
Related Mods
Low cost option to repair Nicro Marine Solar VentsVentilation - Nicro Solar Vent (MacGregor 26X) - July 20, 2020
Like many people, I have Nicro Solar vents on my boat and after 4-5 yrs they fail. As they run basically 24x7, that's not unexpected. Nicro used to sell an overhaul kit with new batter/motor but no longer offer that and suggest that you just buy a ne...
Hatch AdjusterVentilation - - December 1, 2019
The front hatch did not come with a hatch adjuster so there was no easy way to keep the front hatch open except for letting it flop all the back against the deck. This put a lot of stress on the hinges plus it was pretty unattractive. I installed a h...
Hatch LiftVentilation - - December 1, 2019
We installed a gas lift (the same type as used in hatchback cars) to keep the hatch partially open. The lift was available at West Marine, as were the brackets. I would recommend the 40# lift, as anything less seemed to hold the hatch open, but just ...
