M19 Improvements
Published date: December 22, 2020
Modified date: December 26, 2020
  • Boat Type: MacGregor 19, Boat Type
I bought a 1995 M19 over the summer and have been slowly making improvements to the boat for aesthetic, functionality, & safety purposes. When I bought the boat, the electrical system consisted of a single galvanized bolt with about six ring terminals screwed on—each of which had a non-tinned 18AWG wire that went to a marine VHF, the running lights, the cabin lights, the battery, and other crap. Needless to say nothing worked. There was no bilge pump. The engine control was mounted below the starboard settee in an inconvenient place that I kept bumping into. The engine start switch was installed in the starboard rear coaming where you couldn’t reach from the engine control. And a million other crappy things that weren’t well-thought-out or useful. I moved the engine control above the settee and installed a portlight to fill the hole. Added new cabin lights. Installed a bulge pump and entirely new electrical system. Built a storage rack along the port side of the interior. Here are some pics of the improvements—more to come over the next couple of weeks...
Model Year: 1995
Share
Related Mods
  • Drainage Holes
    Drainage Holes
    Miscellaneous - - December 1, 2019
    Here you can see the new lower drainage holes I drilled in the battery and gas compartments. The caulking in the compartment also needed to be redone since it had a few leaks which brought water and gas into the space between the inner and outer shel...
  • Boat Cover
    Boat Cover
    The full boat cover protects the boat against the harsh Australian sun. Without the cover the fibreglass becomes oxidised quickly especially the black around the windows. The cover is easy to put on with a zipper from the mast to the bow. I can do it...
  • Putting a skeg at the rear of the Mac 26X
    Miscellaneous - - January 25, 2019
    We put a 42 inch long X 6 inch deep skeg (short keel) on the aft bottom 43 inches of the boat. First we sanded a 11 inch wide area on the aft center area of the boat down to bare fiberglass. Next we put West Systems Epoxy (from now on just Epoxy) on ...
