Replace stuck steering wheel and Steering Brake 2002
- Boat Type: Steering, 2002, MacGregor 26X, Boat Type
Wanted to add a steering brake to my upgraded steering system. Had to use a 3 jaw puller to remove the old wheel. Tried wd40, pb blaster both overnight.
1. Used 24in breaker bar to remove the old wheel nut. Stabilize wheel.
2. Sprayed pb blaster and wd40 let it sit
3. Used a 1/8in drill bit to make a small indentation for the 3jaw puller to sit in ( do this u won't regret it)
4. Apply the puller and tighten down as shown in pic
5. Hit the middle bolt of the tightened 3/ jaw puller with a power swing and the wheel detached.
6. The steering brake won't install correctly with the alignment of the rack and pinion. If you did install it per their direction the brake would face the 2 o'clock position and allow water into the steering. I placed it at the 6 o'clock position which likely will affect its effectiveness.
Related Mods
Hatchway DoorsCockpit - (MacGregor 26X) - August 17, 2020
As other owners have done, I've replaced the large white door that came with our '02 X. 3/4" plywood with 6 layers of spar urethane (the first 3 thinned 50% for absorption) and an oak piece for the overlap. Still need an inside latch or two when I fi...
Teak Hatch TracksCockpit - (MacGregor 26X) - June 18, 2020
Always hated the stock tracks. Finally realized that you can get to the 'hidden' nuts by removing the bolts to the head so that you can flex the fiberglass enough to access them.
Folding Cockpit TableCockpit - (MacGregor 26X) - April 21, 2020
Laminated hinged cockpit table.Hope you enjoy the mod.
