Cork interior
Published date: March 27, 2021
  • Boat Type: MacGregor 26X, Boat Type
Hi , for this decoration I used a 2mm thick cork roll and a slow-acting water-based glue.
Model Year: 2000
Share
Related Mods
  • Replace stuck steering wheel and Steering Brake
    Cockpit - 2002 (MacGregor 26X) - March 24, 2021
    Wanted to add a steering brake to my upgraded steering system. Had to use a 3 jaw puller to remove the old wheel. Tried wd40, pb blaster both overnight. 1. Used 24in breaker bar to remove the old wheel nut. Stabilize wheel. 2. Sprayed pb blaster and ...
  • Hatchway Doors
    Hatchway Doors
    Cockpit - (MacGregor 26X) - August 17, 2020
    As other owners have done, I've replaced the large white door that came with our '02 X. 3/4" plywood with 6 layers of spar urethane (the first 3 thinned 50% for absorption) and an oak piece for the overlap. Still need an inside latch or two when I fi...
  • Teak Hatch Tracks
    Teak Hatch Tracks
    Cockpit - (MacGregor 26X) - June 18, 2020
    Always hated the stock tracks. Finally realized that you can get to the 'hidden' nuts by removing the bolts to the head so that you can flex the fiberglass enough to access them.
