Steering brake
Published date: May 13, 2021
  • Boat Type: MacGregor 26X, Boat Type
Adjusting ring 20mm
https://www.ebay.de/itm/283765508273?hash=item4211be08b1:g:qFYAAOSwcMJgmvDl
Eye bolts M6 x 60mm
https://www.ebay.de/itm/283826918648?hash=item42156714f8:g:p4EAAOSw9ehgmvgG
Model Year: 2000
Share
  • This site is not responsible for damage done to your boat.
  • When in doubt, consult a professional. Always comply with local and marine codes.
  • Dont drill holes in the bottom of your boat.
  • Happy sailing
Related listings
  • Cockpit seat revision (underside / inside)
    Cockpit - (MacGregor 26X) - May 13, 2021
    The seat was very soft and there were many hairline cracks. The seat was sawn open, new struts laminated in and closed again from below. Covered with gelcoat and topcoat.
  • Cork interior
    Cork interior
    Cockpit - (MacGregor 26X) - March 27, 2021
    Hi , for this decoration I used a 2mm thick cork roll and a slow-acting water-based glue.
  • Replace stuck steering wheel and Steering Brake
    Cockpit - 2002 (MacGregor 26X) - March 24, 2021
    Wanted to add a steering brake to my upgraded steering system. Had to use a 3 jaw puller to remove the old wheel. Tried wd40, pb blaster both overnight. 1. Used 24in breaker bar to remove the old wheel nut. Stabilize wheel. 2. Sprayed pb blaster and ...
