HomeMade Anchor sail
Published date: September 20, 2022
  • Boat Type: MacGregor 26X, Boat Type
Good condition Dacron sailcloth cut from Old used jib. I reinforced each corner with 3 layers of dacron and used v69 bonded polyester thread in a singer heavy duty 4423 sewing machine. Leech and luff reinforced with boltrope made from paracord 550. Brass grommets placed for caribiners. Dimensions are about 3x6ft. Makes for about 9sqft of sail area.
Share
  • This site is not responsible for damage done to your boat.
  • When in doubt, consult a professional. Always comply with local and marine codes.
  • Dont drill holes in the bottom of your boat.
  • Happy sailing
Related listings
  • Handy temporary anchor mount
    Anchoring - anchor (MacGregor 26S) - December 25, 2020
    Not exactly a mod, but an easy, effective, and inexpensive way to keep the anchor handy when you are planning to use it. A #8 anchor rests between the mast tangs at the fore pulpit, and is held in place with a short bungee cord. You will want to put ...
  • Anchor roller
    Anchor roller
    Anchoring - - December 1, 2019
    I mounted the custom anchor roller from Blue Water Yachts on "Sea Breeze." Works great and was not too difficult to install. The bow light is relocated onto a special bracket on the anchor roller. I had to extend (actually I replaced) the wire supply...
  • Anchor Storage
    Anchor Storage
    Anchoring - - November 18, 2017
    Figured how to put the anchor rode and chain in a cloth cooler in the little area forward of the v berth. It works nicely. The little cooler isn't waterproof but makes a nice filter for any gunk that gets on the chain so it won't flow into the bilge....
