Locking Rotating Mast - M26
Published date: December 28, 2022
Modified date: December 28, 2022
  • Boat Type: MacGregor 26M, Boat Type
Through necessity, I bent the mast and it wouldn't rotate from side to side, I decided to "lock" the mast straight ahead until I solved the mast problem. It was pretty simple, drill a hole in the mast foot plate and the plate attached to the bottom of the mast (excuse the lack of technical terms). Dropped in a pin (drop nose pin) and voila, mast locked to not rotate. Not only fixed my mast problem in the short term but I also use it to prevent the mast from rotating to the side when mounting it on the top of the boat for towing. PS: got the mast straightened and it rotates as it should.
Model Year: 2011
Photo Caption: Larger hole is where the boom vang attaches. Smaller hole is where the locking pin goes through.
Share
  • This site is not responsible for damage done to your boat.
  • When in doubt, consult a professional. Always comply with local and marine codes.
  • Dont drill holes in the bottom of your boat.
  • Happy sailing
Related listings
  • Pins for Spreaders
    Pins for Spreaders
    Rigging - (MacGregor 26M) - January 8, 2025
    Trying to reduce the need for tool in setting up the boat. The original locking of the spreader bars onto the bracket on the mast was by small bolts and nuts. I have replaced then with a locking/lynch pin as pictured. Will not rattle loose although I...
  • Tool-free bolt mod
    Tool-free bolt mod
    Rigging - (MacGregor 26S) - May 19, 2023
    Tired of carrying two crescent wrenches in my pocket while rigging/derigging my 26S, I modified some SS bolts to accept split rings and rounded the ends for easy insertion. I do worry that the split rings might catch ropes, but time will tell on that...
  • (back)Stay out of the way!
    Rigging - Backstay (MacGregor 26S) - August 18, 2022
    Moving the backstay so it does not block the ladder and swim platform.
