Guide Post Addition
Published date: April 13, 2023
Modified date: April 28, 2023
  • Boat Type: MacGregor 26X, Boat Type
Several years ago……We found that attempting to land our Mac26X on the trailer in windy and cross current conditions has been challenging :@ :#(and seriously humorous to the boat ramp crowd :p).
We started with two post just rear of the aft axle. … still a problem as it would now straddle the trailer sideways! We tried a good suggestion to add a line from one guide post to the winch post and back to the other guide post. That helped but one had to remember to put it up prior to backing down the boat ramp when retrieving…;);)…
So we added another two guide posts forward of the front axle. (Total of four guide posts.) This has been a substantial improvement!!!!!:):)
In extreme conditions we have still added the additional guide line from the front guide posts to the winch post as a “belt and suspenders” precaution.
Additionally we also now added a Heavy Duty Bungee Cord across from the bottom tails of the forward guide posts to prevent the swing keel from accidentally dropping to the pavement of jamming against the trailer axles should the keel lift line come loose or break in transit. Cheap insurance vs. grinding the keel to a nub when traveling cross country on the highways and byways.
It’s been a nice improvement for us!
Post Script:
Upon using our original setup with the taper out rear posts we found that it was allowing more lateral movement than desired when loadin and didn’t help with centering the boat onto the trailer as much as we had anticipated.
We have since reconfigured and gone with straight vertical rear guide poles which seem to do a better job for us.
We took the old tapered guide poles and have now mounted them to Scrambled’s (our 15 ft runabout) trailer. Waste not/ Want not ;-)
Share
  • This site is not responsible for damage done to your boat.
  • When in doubt, consult a professional. Always comply with local and marine codes.
  • Dont drill holes in the bottom of your boat.
  • Happy sailing
Related listings
  • Added Bow Support Bracket to trailer
    Trailer - (MacGregor 26X) - September 23, 2023
    One last project we finished today before launching was to finalize our bow support on our trailer. We actually got this from the replacement trailer we got and refurbished/adjusted for our runabout Scrambled. The replacement trailer was a Shore-Land...
  • Another Furler Support
    Trailer - Furler (MacGregor 26M) - January 17, 2020
    4" PVC pipe with 1/8" x 3/4" aluminum straps. Velcro straps attach support to mast and furler to support. Finally losing the crutch!
  • Dual axle trailer
    Dual axle trailer
    Trailer - - December 1, 2019
    One of the first mods I made was to add a second axle to the trailer. I just felt more confortable with the added margin. I also knew I was going to add a fair amount of weight (three batteries total, 4-stroke engine, 24 gallon fuel, etc.). Although ...
