Replaced Portlights
Published date: April 30, 2023
  • Boat Type: MacGregor 19, Boat Type
I replaced the plexiglass portlights and added a porthole in the head compartment. I used 3M VHB tape and Dow 795 black sealant for a “screwless” installation. The porthole was bolted through the fiberglass with the heads countersunk before adding the VHB tape so that everything is secure but neat. Very happy with the way this turned out—just need to do a little line of black 795 on the inside…
Model Year: 1995
Share
  • This site is not responsible for damage done to your boat.
  • When in doubt, consult a professional. Always comply with local and marine codes.
  • Dont drill holes in the bottom of your boat.
  • Happy sailing
Related listings
  • Bottom Paint
    Bottom Paint
    Exterior - Bottom Paint (MacGregor 19) - May 5, 2022
    Decided to keep the boat in a slip at our local marina on the Napa River so that we would use her more often. I let her sit in the water at the dock for about three weeks to establish a good waterline, then had the marina handle the project. I would’...
  • Clean Vinyl Cockpit Cushions
    Exterior - Cushions (MacGregor 19) - August 2, 2021
    My vinyl cockpit cushions wouldn’t come clean with soap & water, so I took a chance and tried using soft scrub on a foam disc polisher. Aside from being messy, this was a quick easy way to make the cushions look like new.
  • Rubrail Rehab
    Rubrail Rehab
    Exterior - Rubrail (MacGregor 19) - July 25, 2021
    My rubrail was trashed—it was stiff, brittle, crazed, stained white where compound/wax had gotten on it and had a couple of big chunks missing. I was planning on replacing it, but it seems like a huge job so I was procrastinating… I tried some aceton...
