Easy mod for easy front hatch operation
- Boat Type: Grapevine, TX, MacGregor 26S, Boat Type
2 things - a spring and a self-locking wing nut. The latter is not easy to find - I had to order off Amazon. The spring was in my inventory of spares. I would imagine one could be found at your local big box. Get stainless steel if possible, of course.
This allows the user to pull down and rotate the latch into position, releasing it to hold the latch securely in place. Once the wing nut is adjusted properly, it is not necessary to adjust it further. Road-tested.
This has the added advantage of preventing the latch from inadvertently rotating into the latched position.
- This site is not responsible for damage done to your boat.
- When in doubt, consult a professional. Always comply with local and marine codes.
- Dont drill holes in the bottom of your boat.
- Happy sailing
Related listings
NEW INTERIOR CUSHIONS AND UPHOLSTERY INSTALLEDInterior - (MacGregor 26X) - September 19, 2022
WE FINALLY installed our new 6” thick conformal foam pads! We decided to leave the dinette table down to make things more comfortable while staying aboard and over nightingale in Over Easy. We made a new simple bow berth extension to lengthen that be...
Improving hatch coversInterior - (MacGregor 26M) - September 9, 2022
On my new to me boat, I've noticed where previous owners scratched the hatch areas and floor areas with the long stainless machine screws used to align the hatch covers. I also poured myself a few times and was generally annoyed with the setup. I dec...
Folding door to headInterior - Interior mod (MacGregor 26S) - July 13, 2022
Having a door that folds works so much better.
