New Mid Cleats
- Boat Type: MacGregor 26X, Boat Type
Hi All
Our 2001 Mac26X came with the standard bow and stern cleats which have in general been relatively functional for tying up at the dock, slip and pier but there have been several times when having a set of mid cleats would have been advantageous. Particularly when contending with adverse weather conditions where it would have been beneficial to ad fore/aft spring lines.
To that end we were able to find new cleats that match our existing cleats along with 1/4-20 SST hardware. We mounted them 30 inches forward of the cabin entrance bulkhead. This location was to ensure that the Admiral could easily reach them from the cockpit.
We spent a leisurely couple of hours drilling, sealing with 5200 and bolting up. We used fender washers where possible and regular washers where there were structure limitations. We used self locking nuts as that will ensure things stay put for the long haul. We also made larger hole in the cabin ceiling and install cover plugs to dress things up.
Glad we finally got this accomplished!
Best Regards
Over Easy :-) :-)
- This site is not responsible for damage done to your boat.
- When in doubt, consult a professional. Always comply with local and marine codes.
- Dont drill holes in the bottom of your boat.
- Happy sailing
Related listings
Motor Well Drain ScreenMiscellaneous - Screen (MacGregor 26X) - July 18, 2022
Next we added a engine well drain screen to keep all the nuisance crud, pine needle, acorns, leaves, etc… from wandering down the drain pipe. We found it at Lowes in the kitchen and bath sink accessories section. It’s perforated deburred SST sheet ma...
Repair/Mod for Pedestal Side Panel MountingMiscellaneous - Pedestal (MacGregor 26X) - July 18, 2022
As we may have mentioned previously about the Well-Nuts we put in the pedestal to hold the side panels… didn’t work out as planned ( to put it mildly :| ). After looking at several options we decided to make sections of PVC board blocks and secure th...
Improved Helm Steering ClearanceMiscellaneous - Steering (MacGregor 26X) - July 18, 2022
While we had the pedestal unbolted we decided to adjust our steering wheel. The PO replaced the steering unit and the mounting bracket has a three “ish” inch offset flange. The PO mounted it so the wheel was further aft and the trim collar cone that ...
