installing stern rail seats
Published date: July 18, 2023
  • Boat Type: MacGregor 26M, Boat Type
https://www.instagram.com/p/Cu2GCXMRBYp/
Share
  • This site is not responsible for damage done to your boat.
  • When in doubt, consult a professional. Always comply with local and marine codes.
  • Dont drill holes in the bottom of your boat.
  • Happy sailing
Related listings
  • Teak Swim Platform with Ladder
    Cockpit - (MacGregor 26M) - April 29, 2025
    I wanted to make a better boarding ladder system that was still convenient to lower, raise and stow and would have a wider ladder that was deeper in the water for easier climbing. Also, almost the entire rig is configured with standard hardware which...
  • Companionway hatch board
    Cockpit - Calgary (MacGregor 26X) - December 3, 2023
    The goal was to make the door multi-piece for easier storage. Decided as well to provide a means of securing us inside the boat if needed, for instance in a shady Walmart parking lot. Used HDPE 'cutting board', a 3x3 piece is enough. Cheaper than Sta...
  • Bimini Height Improvement
    Cockpit - Bimini (MacGregor 26X) - July 18, 2022
    And then we modified the Bimini. The Bimini height originally was a bit too low in that one couldn’t stand up in the cockpit where moving about basically bent over. This was more than a bit awkward. We made a pair of extension legs to raise the Bimin...
