My First Mod! Stern Berth Lighting
Published date: September 1, 2023
Modified date: October 21, 2023
  • Boat Type: MacGregor 26X, Boat Type
Hello there! We recently acquired ‘Courageous’ and have found the forum of tremendous benefit.
So here’s my very first modification: lighting for the stern berth/storage area on our 26X. I ran low voltage wire from the battery compartment to the transom, then used a stick-on lighting tape to run it forward along the port side of the low-end of the ceiling, across behind the companionway ladder, and back to the stern the starboard side.
Dobertry Rv Underglow LED Light Kit, $19.99 at Amazon.
VIPMOON L Shape 2 Pin LED Connectors,10 Pcs, $8.99 at Amazon.
For good measure I also installed a lighted switch and fuse for it at the bottom of the battery compartment—it was a convenient place to put it and easy to wire up.
Pro Tip: Don't have the battery compartment switch facing starboard; instead, have it facing aft from the rear of the battery compartment. There's nothing wrong with the way I did it, except that nearly every time I go below I accidentally turn it off with my knee or my foot!
Model Year: 2000
Share
  • This site is not responsible for damage done to your boat.
  • When in doubt, consult a professional. Always comply with local and marine codes.
  • Dont drill holes in the bottom of your boat.
  • Happy sailing
Related listings
  • Anchor Light and Windvane
    Lighting - - December 1, 2019
  • Light In Head
    Light In Head
  • Light in the headroom
