Companionway hatch board Calgary
- Boat Type: Calgary, MacGregor 26X, Boat Type
The goal was to make the door multi-piece for easier storage. Decided as well to provide a means of securing us inside the boat if needed, for instance in a shady Walmart parking lot. Used HDPE 'cutting board', a 3x3 piece is enough. Cheaper than Starboard and I like the light it allows thru. Portlight is from Amazon. It provides a way to see out and ventilation. I'll keep the original door for storage security.
- This site is not responsible for damage done to your boat.
- When in doubt, consult a professional. Always comply with local and marine codes.
- Dont drill holes in the bottom of your boat.
- Happy sailing
Related listings
Bimini Height ImprovementCockpit - Bimini (MacGregor 26X) - July 18, 2022And then we modified the Bimini. The Bimini height originally was a bit too low in that one couldn’t stand up in the cockpit where moving about basically bent over. This was more than a bit awkward. We made a pair of extension legs to raise the Bimin...
Improved Pedestal FeedthroughsCockpit - Pedestal (MacGregor 26X) - July 18, 2022While having to unbolt the pedestal from the cockpit floor I decided that while the cables were removed it was a prime time to investigate the persistent nuisance leak into the aft berth I’ve suspected originates at the two pedestal feed throughs. It...
Steering brakeCockpit - (MacGregor 26X) - May 13, 2021Adjusting ring 20mm https://www.ebay.de/itm/283765508273?hash=item4211be08b1:g:qFYAAOSwcMJgmvDl Eye bolts M6 x 60mm https://www.ebay.de/itm/283826918648?hash=item42156714f8:g:p4EAAOSw9ehgmvgG
