Mac26X Mod for Single Handed Swing Keel Removal & Install
Published date: April 13, 2024
Modified date: April 13, 2024
  • Boat Type: MacGregor 26X, Boat Type
Modification of the swing keel pivot bracket.
Start with removal of ~23 year old corroding bracket
Then take the replacement bracket from Blue Water Yatchs and replace the existing 3/8” dia x 3 inch lift screw with a 1/2” dia x 6 inch SST carriage bolt that is locked in place with an interference fit of the square section under the cap head to the bracket’s slightly enlarged hole and held with a SST Lock washer & nut.
This new longer lift screw lets one self install the swing keel by allowing one to install the bracket by oneself,
go inside and place a washer and nut on the interior exposed threads,
then go back under the boat with the pivot pin holes now fully exposed,
wrangle the swing keel into position by itself,
align and insert new pin with alternating SST & the sacrificial anode Aluminum washers on each side of the keel caputured by the bracket,
insert the new prepared Dynema lift line,
pull line up though to top deck,
then go inside and tighten nut of lift bolt to raise the keel up into place.
(NOTE: Nickel Ease thread lube was throughly applied to the lift screw threads to preclude possible galling).
Well worth the effort to go this route rather than attempting to fit up the keel to the factory bracket and in the blind attempting to thread the unseen short lift screw into the top trunk hole while someone else inside the boat contorts and attempts to put on a washer, lock washer and nut on the end of the lift screw ( while the guy outside struggles with holding the heavy assembly steady and in place.
Best Regards,
Over Easy :-) :-)
Share
  • This site is not responsible for damage done to your boat.
  • When in doubt, consult a professional. Always comply with local and marine codes.
  • Dont drill holes in the bottom of your boat.
  • Happy sailing
Related listings
  • Easy Fwd Fender Retrieval
    Miscellaneous - (MacGregor 26X) - September 1, 2023
    Hi All! We have our fenders rigged to the cabin top lifeline stantion posts as well as the stern rails. This spaces them out reasonably well. We found that getting the forward fenders up and down was a bit of a hassle. Climbing up on the cabin deck w...
  • Modifying the bimini
    Miscellaneous - (MacGregor 26X) - July 24, 2023
    I don't know where the previous owner found this bimini But I've never seen one this tall on another 26X. Any suggestions for how to shorten, and tighten up this thing? Added picture of an actual mod, that I like, the adjustable back stay.
  • Mod to 12 gal tanks on a Mac26X
    Miscellaneous - (MacGregor 26X) - June 25, 2023
    Original Post by OverEasy » Sat Mar 27, 2021 2:16 am Our objective is to prepare Over Easy and ourselves for extended cruising of the Atlantic Intra-Coastal Waterway in 2022. Given the remoteness, narrowness and lengths of many of the waterways we fe...
