Mac26X Swing Keel Bracket and Pin Anti-Corrosion Sacrificial Aluminum Anode Washers
- Boat Type: MacGregor 26X, Boat Type
We have noticed that our Mac26X 304 SST swing keel bracket and pivot pin have suffered measurable galvanic pitting corrosion. While we have checked this over the years and throughly blended out the observed corrosion pitting it has repeatedly returned. We’ve also triple checked that there is not any form of active grounding or other circuit connected to the swing keel bracket assembly.
We tried using zinc washers but they proved to be difficult to find with a 3/8 inch diameter through hole. We also tried to self fabricate the zinc washers but they proved to be too brittle.
As we operate in both salt water, brackish and fresh water environments aluminum was determined to be a valid alternative to zinc.
We took 6061 baseline 2 inch wide x 1/8 inch thick aluminum strap to fabricate several 2”x2” square washers with 1/2” dia center holes.
We placed two of these sacrificial aluminum washers on either side of the swing keel and spaced apart by SST washers to maximize the water exposed surface area.
Aluminum is a lot more robust than zinc and still has good sacrificial anode capability, especially in salt and brackish water environments where we spend a good portion of our time and have incurred the most corrosion issues.
Best Regards,
Over Easy :-) :-)
For those not familiar with how a sacrificial anode material selection works here is a nice reference chart.
The ‘less’ noble metal will get consumed in an electrolytic environment before the ‘more’ noble metal.
So the further apart on the chart the metals are the more apt the ‘less’ noble metal will be consumed in an electrolytic environment.
As you can see Stainless Steel is at the bottom right as the ‘most’ noble metal on the chart.
As mentioned above zinc was too brittle and difficult to obtained… galvanized steel was out as after the (zinc) galvanizing is consumed the steel will rust (and making a Gawd Awful Mess in the process)…. So that is where Aluminum comes into play as a valid sacrificial anode.
- This site is not responsible for damage done to your boat.
- When in doubt, consult a professional. Always comply with local and marine codes.
- Dont drill holes in the bottom of your boat.
- Happy sailing
Related listings
Mac26X Mod for Single Handed Swing Keel Removal & InstallMiscellaneous - (MacGregor 26X) - April 13, 2024Modification of the swing keel pivot bracket. Start with removal of ~23 year old corroding bracket Then take the replacement bracket from Blue Water Yatchs and replace the existing 3/8” dia x 3 inch lift screw with a 1/2” dia x 6 inch SST carriage bo...
Easy Fwd Fender RetrievalMiscellaneous - (MacGregor 26X) - September 1, 2023Hi All! We have our fenders rigged to the cabin top lifeline stantion posts as well as the stern rails. This spaces them out reasonably well. We found that getting the forward fenders up and down was a bit of a hassle. Climbing up on the cabin deck w...
Modifying the biminiMiscellaneous - (MacGregor 26X) - July 24, 2023I don't know where the previous owner found this bimini But I've never seen one this tall on another 26X. Any suggestions for how to shorten, and tighten up this thing? Added picture of an actual mod, that I like, the adjustable back stay.
