Mac26X Swing Keel Lift Line Traveler Pulley to Reduce Require Force to Raise Keel by Half
- Boat Type: MacGregor 26X, Boat Type
Hi All!
We’ve found that the pull force to raise our swing keel on our Mac26X can be a bit much at times. Especially when tired and sore or when the conditions are adverse.
To that end we decided to add a traveler pulley system when recently changing out our old lift line with Dynema which is not only considerably stronger but also MUCH more slippery.
Now on to the addition of a traveler pulley system to reduce the pull required to raise the swing keel by half.
- Spliced in an eye to the end of the Dynema line then added a whipping to aid in locking the hollow core splice.
- Added a whipped eye to the end of the old braided cored nylon lift line (which is easier to grip than Dynema ) and secured to a convenient stanchion.
- Threaded the free end through the traveler pulley,
- Connected the pulley frame to the Dynema lift line eye and
- Then routed the hand line so the winch can now be used (if desired) and to the open top cinching pawls.
Testing demonstrated that the effort required to raise the swing keel was CONSIDERABLY reduced! :-) :-)
Best Regards,
Over Easy :-) :-)
- This site is not responsible for damage done to your boat.
- When in doubt, consult a professional. Always comply with local and marine codes.
- Dont drill holes in the bottom of your boat.
- Happy sailing
Related listings
Mac26X Swing Keel Bracket and Pin Anti-Corrosion Sacrificial Aluminum Anode WashersMiscellaneous - (MacGregor 26X) - April 13, 2024We have noticed that our Mac26X 304 SST swing keel bracket and pivot pin have suffered measurable galvanic pitting corrosion. While we have checked this over the years and throughly blended out the observed corrosion pitting it has repeatedly returne...
Mac26X Mod for Single Handed Swing Keel Removal & InstallMiscellaneous - (MacGregor 26X) - April 13, 2024Modification of the swing keel pivot bracket. Start with removal of ~23 year old corroding bracket Then take the replacement bracket from Blue Water Yatchs and replace the existing 3/8” dia x 3 inch lift screw with a 1/2” dia x 6 inch SST carriage bo...
Easy Fwd Fender RetrievalMiscellaneous - (MacGregor 26X) - September 1, 2023Hi All! We have our fenders rigged to the cabin top lifeline stantion posts as well as the stern rails. This spaces them out reasonably well. We found that getting the forward fenders up and down was a bit of a hassle. Climbing up on the cabin deck w...
