Oops:-(
Published date: April 13, 2024
Modified date: April 13, 2024
  • Boat Type: MacGregor 26X, Boat Type
Oopsies :-(
Duplicate entry
Sorry
Share
  • This site is not responsible for damage done to your boat.
  • When in doubt, consult a professional. Always comply with local and marine codes.
  • Dont drill holes in the bottom of your boat.
  • Happy sailing
Related listings
  • Mac26X Swing Keel Lift Line Traveler Pulley to Reduce Require Force to Raise Keel by Half
    Miscellaneous - (MacGregor 26X) - April 13, 2024
    Hi All! We’ve found that the pull force to raise our swing keel on our Mac26X can be a bit much at times. Especially when tired and sore or when the conditions are adverse. To that end we decided to add a traveler pulley system when recently changing...
  • Mac26X Swing Keel Bracket and Pin Anti-Corrosion Sacrificial Aluminum Anode Washers
    We have noticed that our Mac26X 304 SST swing keel bracket and pivot pin have suffered measurable galvanic pitting corrosion. While we have checked this over the years and throughly blended out the observed corrosion pitting it has repeatedly returne...
  • Mac26X Mod for Single Handed Swing Keel Removal & Install
    Modification of the swing keel pivot bracket. Start with removal of ~23 year old corroding bracket Then take the replacement bracket from Blue Water Yatchs and replace the existing 3/8” dia x 3 inch lift screw with a 1/2” dia x 6 inch SST carriage bo...
