Pins for Spreaders
- Boat Type: MacGregor 26M, Boat Type
Trying to reduce the need for tool in setting up the boat. The original locking of the spreader bars onto the bracket on the mast was by small bolts and nuts. I have replaced then with a locking/lynch pin as pictured. Will not rattle loose although I do position them in the down position so any movement doesn't effect the wire lock.
- This site is not responsible for damage done to your boat.
- When in doubt, consult a professional. Always comply with local and marine codes.
- Dont drill holes in the bottom of your boat.
- Happy sailing
Related listings
Tool-free bolt modRigging - (MacGregor 26S) - May 19, 2023Tired of carrying two crescent wrenches in my pocket while rigging/derigging my 26S, I modified some SS bolts to accept split rings and rounded the ends for easy insertion. I do worry that the split rings might catch ropes, but time will tell on that...
Locking Rotating Mast - M26Rigging - (MacGregor 26M) - December 28, 2022Through necessity, I bent the mast and it wouldn't rotate from side to side, I decided to "lock" the mast straight ahead until I solved the mast problem. It was pretty simple, drill a hole in the mast foot plate and the plate attached to the bottom o...
(back)Stay out of the way!Rigging - Backstay (MacGregor 26S) - August 18, 2022Moving the backstay so it does not block the ladder and swim platform.
