Tiller clutch rope re-route Grapevine
- Boat Type: 712 N Lucas Drive, Grapevine, Grapevine, MacGregor 26S, Boat Type
I consider my Tiller Clutch to be essential for single-handing, but two things I did not like about the original rope arrangement (see yellow lines in first photo) were how they interfered with seating and that releasing them to allow the tiller to swivel upwards (to allow lazarette access) required pushing the tiller way over toward the coaming so the rope would become slack enough to unclip. This was very inconvenient if I wanted to maintain course.
With this new method, the rope path allows full use of the benches on both sides. Slipping the rope off either of the hooks allows it to go slack so one can unclip it and raise the tiller upright to allow access to the lazarette.
To cut down on friction I cut a pieces of Delrin rod in half and epoxied it to either side of the clutch (see photo). I had planned to use pulleys at the aft attachment points, but could not find exactly what I was looking for, so went for the quick, cheap option of SS eye-screws and cut an opening to allow for easy removal of the rope. There is some friction, but not enough to be a problem.
I almost screwed up with the eye-screw placement. Any further back would have caused the rope to tighten when the tiller was pushed all the way port or starboard, so be mindful of that if you want to try this mod.
- This site is not responsible for damage done to your boat.
- When in doubt, consult a professional. Always comply with local and marine codes.
- Dont drill holes in the bottom of your boat.
- Happy sailing
Related listings
Advice on sailing to Bahamas from FloridaSailing - - January 27, 2017Hello everyone I plan to sailing my Mac to Bahamas in June 2017 from Florida, have anyone here tried that and if so, what to prepare for and look out for? Also I don't really want to be the only sail boat going over, I know speed boats and fishing bo...
ForesailsSailing - - January 13, 2017I bought a Mac 26 and was assured it had the std jib, but it has the genoa. So I need to get some smaller foresails. I have seen storm jibs from 36sqft upwards. That seems pretty small to me, does anyone have a recommendation for a foresail to run in...
asymmetrical spinnakerSailing - - May 19, 2016I know there is a lot of post but what is a good size for my 26m. im looking at asymm spinnaker I can get fairly cheap but maybe its too big?? they are advertising it 3/4 oz, 30 luff, 35 leech, 22 foot. I no expert by far and will be hoping some help...
