Motor Well Drain 26X Ohio
- Boat Type: Ohio, MacGregor 26X, Boat Type
Had slow drainage from my motor well since I purchased the boat. Unsure If drain was original?
I Replaced all piping/tubing
Supplies
Two 1-inch PVC 90deg barbed fittings.
Clear PVC Tubing inner diam 1-inch:
13in clear PVC tubing
Two 3-inch segments of 1in (interior) PVC tubing.
6x Adjustable Screw Hose Clamps.
- This site is not responsible for damage done to your boat.
- When in doubt, consult a professional. Always comply with local and marine codes.
- Dont drill holes in the bottom of your boat.
- Happy sailing
Related listings
Engine Load Distribution/Reinforcement PlateMotor - Reinforcement (MacGregor 26X) - July 18, 2022In preparation for our new engine we decided to take the opportunity to add a new additional load distribution/reinforcement plate. The new 3/4” thick G-10 transom reinforcement plate was cut to size, drilled, edge routered both sides, primed and coa...
Mod to Fuel System (Selector/Filter/Regulator/Primer) for DualMotor - Fuel tank (MacGregor 26X) - July 23, 2021In preparing Over Easy to cruise the Atlantic ICW we chose to make some modifications to our vessel. We upgraded our fuel system to incorporate: 1) dual 12 gallon tanks 2) external fuel filter/separator 3) 3/8 diameter fuel lines 4) 3-way fuel select...
Replace steering systemMotor - (MacGregor 26X) - May 12, 2021Seastar "Back Mount Rack" 8ft./244cm Länge Bellows: https://www.amazon.de/gp/product/B088P2N6SB/ref=ppx_yo_dt_b_asin_title_o09_s00?ie=UTF8&psc=1
