HD Ratchet (pull forward) straps
- Boat Type: Illinois, MacGregor 26X, Boat Type
The 'Mac Bump' process never worked well with anti-skid brakes to bounce the boat forward on the trailer. I use two (2) HD rachet straps (2"x27' ~$12 each) with the rachet bolted to front of trailer and the other end of strap attached to two eyebolts that are my top engine mount bolts (I also use these eyebolts for attachment of my stern anchor bridle). For saltwater applications the HD ratchets are available in stainless steel (Unicornstainless.com). I tension the straps and drive a short distance (with assistance of RR tracks and pothole bouncing) the boat will move forward. The strap is low stretch and boat moves ~1 inch per tensioning with no risk of launching aggressively into the 'V' stop. After 4~5 iterations the boat is in or near the 'V' where I want it to be. I have a 26X on a 26M single axle alum trailer.
Published by: Closehaul
- This site is not responsible for damage done to your boat.
- When in doubt, consult a professional. Always comply with local and marine codes.
- Dont drill holes in the bottom of your boat.
- Happy sailing
Related listings
A ladder I builtTrailer - (MacGregor 26X) - October 29, 2025I have a dual axle aluminum trailer. It did not come with a ladder so I made one for the X. It works well for me to climb up it on the rungs. I am 240 lbs and they do not flex or sag. Hope this gives y'all ideas.
Mast/Furler Transport ConfigurationTrailer - (MacGregor 26X) - August 17, 2025I have a 2000 26X with mast crutch in the steering pedestal. For long distance trailering I remove the spreaders and spiral wrap all the stays, shrouds, halyards, etc., to the mast. Also, I added a U-bolt to the top of mast (I also use this attachmen...
Added Bow Support Bracket to trailerTrailer - (MacGregor 26X) - September 23, 2023One last project we finished today before launching was to finalize our bow support on our trailer. We actually got this from the replacement trailer we got and refurbished/adjusted for our runabout Scrambled. The replacement trailer was a Shore-Land...
