Mast/Furler Transport Configuration
- Boat Type: Illinois, MacGregor 26X, Boat Type
I have a 2000 26X with mast crutch in the steering pedestal. For long distance trailering I remove the spreaders and spiral wrap all the stays, shrouds, halyards, etc., to the mast. Also, I added a U-bolt to the top of mast (I also use this attachment point for a 'safety forestay' when sailing) and move the forestay/furler attachment up to this U-bolt which enables the furling drum to rest under the bow pulpit instead of cantilevering in front. Also, I removed the stop bolt from the mast crutch in the steering pedestal and allow the crutch to lower to the cockpit floor (it rests on a 0.5" masticated rubber pad to distribute load and absorb shocks). When commissioning for sailing I simply lift the mast crutch to the higher position and insert a philips screwdriver in the hole to support (to enable reinstalling spreaders). Lastly, I fabricated a center support at the mast step which (with eye screws and lynch pins) provide attachment points for the boom and MR pole. A short length of chain supports the other end of boom and furling drum under the mast pulpit. The mast is nearly horizontal in this configuration and makes for worry-free trailering. Another advantage is I can reach and remove the windex on top of mast from the stern without a ladder. Lastly, with the boom and MR pole topside, there is more room below for Walmart camping enroute to your cruising area. This is a lot of work if only trailering a few miles - but when trailering several hundred miles - it is well worth the effort.
Published by: Closehaul
- This site is not responsible for damage done to your boat.
- When in doubt, consult a professional. Always comply with local and marine codes.
- Dont drill holes in the bottom of your boat.
- Happy sailing
Related listings
HD Ratchet (pull forward) strapsTrailer - (MacGregor 26X) - August 17, 2025The 'Mac Bump' process never worked well with anti-skid brakes to bounce the boat forward on the trailer. I use two (2) HD rachet straps (2"x27' ~$12 each) with the rachet bolted to front of trailer and the other end of strap attached to two eyebolts...
Added Bow Support Bracket to trailerTrailer - (MacGregor 26X) - September 23, 2023One last project we finished today before launching was to finalize our bow support on our trailer. We actually got this from the replacement trailer we got and refurbished/adjusted for our runabout Scrambled. The replacement trailer was a Shore-Land...
Guide Post AdditionTrailer - (MacGregor 26X) - April 13, 2023Several years ago……We found that attempting to land our Mac26X on the trailer in windy and cross current conditions has been challenging :@ :#(and seriously humorous to the boat ramp crowd :p). We started with two post just rear of the aft axle. … st...
