Drink Holder + 12VDC
- Boat Type: Illinois, MacGregor 26X, Boat Type
Drink holder model #54210300 from ssicustomplastics.com fits nicely in my 26X helm pedestal. I use it more to hold my VHF handheld radio than drinks. Added a 12VDC receptacle in the top of the holder which is a dry location. Convenient location to plug in my spotlight when a neighbor is dragging onto me in the anchorage at night. SSI makes quality OEM marine components.
Published by: Closehaul
- This site is not responsible for damage done to your boat.
- When in doubt, consult a professional. Always comply with local and marine codes.
- Dont drill holes in the bottom of your boat.
- Happy sailing
Related listings
Companionway hatch boardCockpit - Calgary (MacGregor 26X) - December 3, 2023The goal was to make the door multi-piece for easier storage. Decided as well to provide a means of securing us inside the boat if needed, for instance in a shady Walmart parking lot. Used HDPE 'cutting board', a 3x3 piece is enough. Cheaper than Sta...
Bimini Height ImprovementCockpit - Bimini (MacGregor 26X) - July 18, 2022And then we modified the Bimini. The Bimini height originally was a bit too low in that one couldn’t stand up in the cockpit where moving about basically bent over. This was more than a bit awkward. We made a pair of extension legs to raise the Bimin...
Improved Pedestal FeedthroughsCockpit - Pedestal (MacGregor 26X) - July 18, 2022While having to unbolt the pedestal from the cockpit floor I decided that while the cables were removed it was a prime time to investigate the persistent nuisance leak into the aft berth I’ve suspected originates at the two pedestal feed throughs. It...
