7-gallon Reservoir location
Published date: August 19, 2025
Modified date: August 24, 2025
  • Boat Type: Illinois, MacGregor 26X, Boat Type
The Aquatainer 7-gallon fits perfectly in the 26X battery box location on port side behind galley with no trimming required. Held in place with HDPE cage. Suction hose with strainer (inside container) fits thru the vent with a 90 deg fitting. Pump (1.2GPM 45PSI) is mounted behind the container. Attenuator (1 liter) is mounted just forward of the pump on the inside of the galley. Extra water jugs are carried forward under the V berth. I like the battery location as it is easy to fill or just open lid to see how much water remaining.
Published by: Closehaul
Share
  • This site is not responsible for damage done to your boat.
  • When in doubt, consult a professional. Always comply with local and marine codes.
  • Dont drill holes in the bottom of your boat.
  • Happy sailing
Related listings
  • “Mini” A/C Condensate Bilge
    Water Systems - (MacGregor 26X) - March 4, 2023
    It’s March 4th, Saturday night, and I’m deep into the bilges of Over Easy having just completed a new Mini Air Conditioner Condensate Darwin Bilge! Ta Da!!! We had wanted to get this accomplished ever since we installed the A/C in Over Easy! It sorta...
  • Bilge pump
    Bilge pump
  • Faucet
    Faucet
