Companionway Screen
Published date: August 28, 2025
Modified date: August 28, 2025
  • Boat Type: Illinois, MacGregor 26X, Boat Type
The companionway washboard in my 26X was cumbersome to use and store. I use it for transport and storage (when not aboard) only. When cruising, it stays in the truck. I fabricated a roll-up screen/rain cover using HD (dog resistant) screen and 100mil fabric reinforced vinal. Top is sandwiched between alum flat stock and pop riveted. Mounting is double nut to existing hatch handle bolts. During the day (when not needed) it compactly rolls up for easy storage. When installed, a simple shoestring enables tying the rolled vinal when not raining. If raining, I pull the lower portion to the steering pedestal to stay dry while allowing some air movement. The 'pet screen' will allow 'no-seeums' but is effective against normal mosquitoes. Must pack grocery bags in 4 corners of sliding hatch to make mosquito tight. Have used for over 10 yrs and still functioning effectively.
Published by: Closehaul
Share
  • This site is not responsible for damage done to your boat.
  • When in doubt, consult a professional. Always comply with local and marine codes.
  • Dont drill holes in the bottom of your boat.
  • Happy sailing
Related listings
  • Diesel heater install (26m, outside installation)
    Ventilation - Zurich (MacGregor 26M) - May 31, 2025
    hello I installed a diesel air heater to extend the boating season — to enjoy some cozy moments in late autumn and early spring, and maybe even spend time at a beautiful anchorage in winter (with a Swiss cheese fondue ????). Important: No interior in...
  • Adjustable spring hatch prop
    Ventilation - hatch (MacGregor 26S) - June 15, 2021
    I replaced the cantankerous screw-to-tighten forward hatch prop with a stainless steel spring prop. The spring prop provides support automatically, then collapses easily to close, but I still wanted to be able to adjust between fully and partially op...
  • Mac 26X Hatchway Screens
    Ventilation - (MacGregor 26X) - August 15, 2020
    Made some ventilation/bug hatchway screens. I believe this material is used for making RV screen porches. Also looks similar to what is sold at Home Depot or Lowe's in garden section for greenhouses. (Which all means I don't remember who gave it to m...
