Forward Cleat
Published date: January 3, 2004
  • Boat Type: Boat Type
I run a roller furling when I'm on extended cruises and when I day or weekend sail on the lakes I use a hank-on sail.....(Makes my set up time much faster).....Anyways, I found when the hank-on sail was lowered it covered my cleat and made it difficult to get at when anchoring or docking at a marina/boat ramp..So I moved them back between the forward rail....(I had to relocate them, anyways, when I added my bow plank).....But its was another improvement to the mac and I'm glad it happened....The forward cleat's are now in a much, much, better location whenever its necessary to tie off...and that raised fiberglass lip (I don't know why its there) seems to be a plus....The hard part of this mod was removing and replacing all the flotation.
Published by: L Scott
Model Year: 2004
Share
Related Mods
  • Handy temporary anchor mount
    Anchoring - anchor (MacGregor 26S) - December 25, 2020
    Not exactly a mod, but an easy, effective, and inexpensive way to keep the anchor handy when you are planning to use it. A #8 anchor rests between the mast tangs at the fore pulpit, and is held in place with a short bungee cord. You will want to put ...
  • Anchor roller
    Anchor roller
    Anchoring - - December 1, 2019
    I mounted the custom anchor roller from Blue Water Yachts on "Sea Breeze." Works great and was not too difficult to install. The bow light is relocated onto a special bracket on the anchor roller. I had to extend (actually I replaced) the wire supply...
  • Anchor Storage
    Anchor Storage
    Anchoring - - November 18, 2017
    Figured how to put the anchor rode and chain in a cloth cooler in the little area forward of the v berth. It works nicely. The little cooler isn't waterproof but makes a nice filter for any gunk that gets on the chain so it won't flow into the bilge....
