Water Tank - Under Cooler
Published date: April 7, 2004
  • Boat Type: Boat Type
I installed a 23.5 gallon Nauta flexible water tank in the space below the cooler liner. I lined the area with carpet to prevent chafing, this includes the bottom of the cooler liner. I chose 3/8"ID 1/2"OD polyethylene tube because it is listed as "does not add taste or odor." It fit the Whale electric pump perfectly. The deck fill is located at the port, aft corner of the aft dinnette seat directly above the tank. I purchased a brass hose fitting w/valve to use as a filler (center of pic). The stats are as follows:
Capacity = 16 gallons (just as the liner lifts)
GPH = 1.5
Cost = Tank $145.00
90* fittings = $35.00
Deck Fill (stainless) = $40.00
1/2" Polyethylene Tubing, 25 feet = $5.99
See my "A Place For Everything Galley" mod for sink and faucet info.
Water tastes good. The tubing is gasing off a bit but it should go away soon. The tank does not flavor the water at all (so far).
If I wanted, I could fit a long narrow bag on the outside of the ballast tube (extending up to the forward seat)and pick up another 10 gallons. It would utillize a space that is not normally used for anything, although I do store my head treatment and engine oil there.
Published by: Don T
Model Year: 1995
Share
Related Mods
  • Bilge pump
    Bilge pump
  • Faucet
    Faucet
  • Water tank and deck fitting
