Freshwater System
Published date: April 11, 2004
  • Boat Type: Boat Type
The Plastimo 26gal flexible tank is located below the front
dinette seat (and extends under that side of the V-berth). The
tank is filled by way of a deck fill located above the head
compartment. The 1 1/2 inch fill hose goes down the forward
bulkhead of the head compartment, pass through into the aft
dinette seat with an elbow fitting, then immediately takes a right
with another elbow, and makes its way up to the front dinette
seat.
The pump is a Jabsco/Flojet SensorMax 3.7gpm variable speed,
mounted to the aft wall of the front dinette seat. Automatic
freshwater pumps work by activating when a drop in pressure in
the line (when a faucet is opened) is detected. A normal
automatic pump runs at only full speed, so to prevent excessive
cycling of the pump, an accumulator tank is used as a "buffer"
for water pressure. The SensorMax pump eliminates the need
for an accumulator tank by using a pressure sensor tied to a
variable speed pump that only runs the pump as fast as needed
to supply the line with a constant pressure, regardless of
whether the faucet is opened just a little, or all the way.
The T fitting coming off of the output side of the pump was
mainly the result me needing a female-female coupler (I could
only find a T), but the plugged port of the T might be used for
adding cockpit shower later.
After this is a water filter (which does really seem to improve the
taste of the water... it's still a little "plasticky" but it's certainly
drinkable), then another T that sends 3/8" lines to the galley and
head faucets. The galley line is secured along its route to the
underside of the "ledge" of each seat compartment, which keeps
it (and some 12v wiring) out of the way.
The faucets are Shur-Flo (they make a similar faucet that has a
switch for turning on manually-activated pumps, but the switch
is not needed for an automatic pump installation like this). The
faucets are mounted on white light switch plates from Home
Depot.
The system works very well. My first mate was impressed... isn't
that the most important thing?
Published by: mike
Model Year: 2004
Share
Related Mods
  • Bilge pump
    Bilge pump
  • Faucet
    Faucet
  • Water tank and deck fitting
