VHF Radio
Published date: December 1, 2019
  • Boat Type: Boat Type
I mounted an Apelco VHF radio under the distribution box in the cabin on the port side. With some effort I was able to route all the wires including the antenna behind the cabin liner. In the upper right of the large photo you can see where I mounted the thru deck co-ax connector. This gets connected to the co-ax that runs inside the mast. Finally in the lower picture you can see the coil type antenna at the top of the mast with a tell-tale tied to it. Also in the picture you can see the GPS antenna.
Published by: MS Classifieds
Model Year: 1999
Share
Related Mods
  • VHF Radio, Hooks
    VHF Radio, Hooks
    Instruments - - December 1, 2019
    (A) shows the VHF radio we had installed. The guy doing the installation ran into the lower-upper liner problem and decided to just run the power lines outside the wall for a short distance from the upper liner and then into the side of the house bat...
  • VHF Antenna
    VHF Antenna
    The VHF antenna cable (B) passes through the deck near the mast base. When you drill you hole for the cable, you have to watch for two things: * Make sure that you drill far enough to the side so that you do not hit the metal backing plate (A). * Mak...
  • VHF Antenna
    VHF Antenna
    This shows where the antenna cable exits the deck. It comes out right next to the conterboard cable without rubbing against it. This end connects with the antenna cable exiting the mast on the same side. To get the coaxial antenna cable to come out t...
