Battery upgrade
- Boat Type: Boat Type
I moved the original battery into the v-berth storage area and added a starter and an additional house battery. On the '99 Mac 26X models the area around the vent hole and splashguard is not level. I first installed a 2x4 on its edge along the aft part of this area. Next I cemented and screwed a 3/8" plywood floor to the fiberglass and 2x4. I placed the batteries on top of this platform in the configuration shown in the larger picture using notched blocks of wood to hold the batteries in place. E1 is the starter battery and H1 and H2 are the deep cycle house batteries. H2 is the original battery at about 85 amp-hours (my estimate based on size). The one I added, H1, is 115 amp-hours for a total of 200 amp-hrs. (I plan to add covers for the positive battery posts.) I mounted a plywood panel to the bulkhead behind the splash guard for mounting 3 on-off battery switches, fuses (60 amp main distribution and 200 amp for inverter) and a West Marine battery combiner. The lower part of the picture shows the batteries at an angle thru the storage area under the forward dinette seat. In this picture you can see portions of all three batteries and the common grounding post. I used 4 gauge welding cable to carry the current to the engine and 10 gauge to the DC distribution panel.
Published by: MS Classifieds
Related Mods
12V Plug, ScreenElectrical - - December 1, 2019
This picture shows a 12V plug that I added just inside the companionway, above the head door. There is a convenient, out of the way place in the corner in the corner of the head for the inside part of the plug. The wiring runs above the head door, th...
RewiringElectrical - - December 1, 2019
(A) is the power cables coming from the VHF and the compass. (B) is a bus bar that I glued onto the wall in the battery compartment. Wires run from the battery to this, and then to other circuits in the boat. I put a new heavier marine-grade cable fr...
No wiring other than the VHF power cords (I didn't do it) and a short wire from the fan are exposed in the interior. With patience, everything can be run through the conduits. All along the conduits are plastic hole covers from where the factory need...
