Fire Extinguishers
Published date: December 1, 2019
  • Boat Type: Boat Type
I mounted three fire extinguishers in our Mac 26X. I mounted a smaller model just behind the fore dining table seat against the starboard cabin wall in the v-berth area (see upper left part of graphic). I wanted one near the front hatch entrance/exit so it was accessible from that area. I mounted a second larger model to the starboard side of the aft berth entrance with thru bolts into the head (see upper right portion of the graphic). This is readily accessible for galley fires or exit/entry thru the companion way hatch. Finally I mounted a small (PWC type) extinguisher under the helmsman seat. I wanted one in the cockpit so that if the fire started in the cabin when we were in the cockpit I could enter the cabin with extinguisher in hand. You can see this in the right portion of the lower picture where the helmsman seat is in the up position. (Not the best picture, but one I had.)
Published by: MS Classifieds
Model Year: 1999
Share
Related Mods
  • Fire extinguisher
    Fire extinguisher
    Safety - - December 1, 2019
    A fire extinguisher found a good place between the headrom and the companionway. I placed it intentionally slightly off center: Something else will find its place there too. May be the winch handle with a better holder than the current quick-and-dirt...
  • Ballast tank level LED
    Safety - - January 17, 2018
    Hello all I put a reed switch near the vent hole of the ballast tank. And a LED to show me that the tank is full. Works fine, had no problems so far, chaep, does not eat power... Also you can see the vent pipe. And still I can check with the finger i...
  • Mastreb Emergency Bilge Pump
    Safety - - May 10, 2015
    I made a cheap emergency bilge pump based on Mastreb's idea from the following post: http://www.macgregorsailors.com/forum/viewtopic.php?f=8&t=23775&p=291105&hilit=Installing+a+bilge+pump#p291105 Actually, the Rule 2000 was rather expensive, so I wen...
