Anchor roller
Published date: December 1, 2019
  • Boat Type: Boat Type
I mounted the custom anchor roller from Blue Water Yachts on "Sea Breeze." Works great and was not too difficult to install. The bow light is relocated onto a special bracket on the anchor roller. I had to extend (actually I replaced) the wire supplying current to the light. The original was not long enough. By carefully disconnecting the original light wire I was able to attach a 16-gauge marine wire to the original crimp terminals inside the light. The only splice is inside the boat above the v-berth. Some day I'll rewire from there back to the distribution panel.
Published by: MS Classifieds
Model Year: 1999
Share
Related Mods
  • Bow Plank
    Bow Plank
    Anchoring - - January 3, 2004
    Several months ago when sailing the Texas ICW I had to anchored many times..I found that under certain windy conditions the anchor rode would shift from side to side (port to starboard) and would catch on my running light and snap it off..I made a si...
  • Forward Cleat
    Forward Cleat
    I run a roller furling when I'm on extended cruises and when I day or weekend sail on the lakes I use a hank-on sail.....(Makes my set up time much faster).....Anyways, I found when the hank-on sail was lowered it covered my cleat and made it difficu...
  • Anchor Locker Modification
    Anchoring - - April 27, 2000
    I found it annoying that you couldn't close the hatch on the anchor locker when you had some of the rode still in the locker. I ground out a notch in the hatch cover so that the rode could pass through with the cover closed. We have an anchor mount o...
