Communications/entertainment
Published date: December 1, 2019
  • Boat Type: Boat Type
Greetings from Melbourne, Australia!
I wanted to add music (radio/cassette/CD stacker) to 'Macanudo', my '97 26X.
A 27Mhz radio was already installed hanging from a bracket just inside the companionway (hence there was power). It seemed a practical spot as it was out of the way, yet easily reached from the cockpit and below. My boat has a bimini which protects this area really well when needed.
I first made up a cardboard model for the proposed bulkhead to be used as a template for the acrylic fabricator. That was fiddly as there was not a straight line to be had. I allowed plenty of room at the back of the module for installation/repair access.
The white acrylic module was then fixed using small white plastic 'L' brackets attached with stainless steel screws/bolts. Two of those were through the superstructure - the back of the port-side seat.
One was from the deck, between two cleats and a couple in the front of the module, into a channel.
I left the radio in the existing bracket and the other pieces were fixed to shelves that were fabricated into the module.
After some deliberation choosing speaker location I decided I would not fix the cockpit speakers. Instead I drilled a small hole high and to the rear of each of the fuel lockers and installed a female RCA plug (gold-plated to avoid corrosion) and siliconed to seal against water entering down below. I had some existing small outdoor speakers that I added a length of cable (about 2m or 6 feet) with a male RCA plug on the end and just plugged them in. The speakers and excess cable reside in the fuel locker, snugly against each fuel tank, but easily removed for placement elsewhere. The cables I ran under the deck, between the deck and inner shell. The styrene foam needed to be removed and and made a huge mess - it of course was replaced when cabling was complete.
The front speakers I installed in the front bulkhead, with the cables run down (with difficulty) the port side, between the outer and inner shells.
The sound is really good. The Pioneer system was pulled out of a car. Using the fader you can balance the volume between below and the cockpit.
Published by: MS Classifieds
Model Year: 1997
Share
Related Mods
  • Circulation Fan, Interior Light, Gear Hammock
    Interior - - December 1, 2019
    (A) is a circulation fan which pivots up and out of the way when not in use. (B) is a red/white flourescent light. The red light is nice for night sailing. (C) is the gear hammock over the galley area. Published by: Heath
  • Head Door Handle
    Head Door Handle
    This is an easy one that makes a big difference. Our boat came from the factory without a handle on the head door. In order to close it you had to grab the little latch. I installed a nice little wooden handle on the inside of the head door so that i...
  • "SAFETY HAND RAIL"
    "SAFETY HAND RAIL"
    To accomodate my 2 year old and an 80+ family members, I installed a stainless steel 16" handrail (from medical supply store) with 1/4" through bolts (4) and 2 #10x1 1/2 steetmetal screws into the port gangway entrance frame. This accomodates the gan...
