Doors
Published date: December 1, 2019
  • Boat Type: Boat Type
I purchased the boat used from a guy who had put two plexiglass doors (tinted) to replace the entranceway hatch/door on the original. These open outwards, and are made up of two identically shaped sections, one left and one right, essentially splitting the original shape right down the middle. As the original doors did not have removable hinges when we got it, we got hinges from West Marine so the doors can be slid off the hinge pins and put down below when sailing. Then, locks are put in place so we can lock the boat securely.
This allows us to stay the night on the boat quite comfortably, look out the back during the evening, open one door or the other as desired, and remove both for sailing. In addition, we have now mounted one 4"x8" stainless steel "locker" type vent in each door, adding ventilation to the boat without cutting holes in the fiberglass.
Published by: MS Classifieds
Model Year: 1997
Share
Related Mods
  • 12’ KeelGuard
    12’ KeelGuard
    Exterior - (MacGregor 26M) - December 29, 2019
    I had some scratches and dings on the bow of my boat from the last 14 years of constant use. I was considering doing some gelcoat repair, but that is expensive and difficult, and will just get scratched and dinged again anyway. Instead, I added the l...
  • Teak treads on the swim ladder
    Exterior - - December 1, 2019
    The standard swim ladder is not very comfortable to use. So I added teak treads when I realized that such a thing were readily available, perfectly shaped below to fit onto the stainless steel tubes. Cost: $7 plus 4 SS screws and som 3M 5200 (or simi...
  • Vents
    Vents
    I found after having my 26x anchored in Monroe Harbor in Chicago for two seasons that mildew buildup was a problem, as was a musty smell. I have now installed four vents. The first is in the forward hatch, and it is a common plastic vent from West Ma...
