Lights & Electrical System
Published date: December 1, 2019
  • Boat Type: Boat Type
We put in two additional interior lights. One over the rear berth, and one in the head. both are white plastic from West Marine, and have both the white and red bulbs (red reduces the impact on your night vision when you turn in on).
The one in the head has been mounted to the round black plastic cover overhead, and effectively covers it up. From there we ran the wire down inside the trim fiberglass in the head, and drilling a small hole, out to the rear berth area, another small hole takes the wire into the hold area, and across to the battery.
Similarly, we put the same model light over the rear berth so we can read at night.
Pictures to be submitted soon.
Published by: MS Classifieds
Model Year: 1997
Share
Related Mods
  • 12V Plug, Screen
    12V Plug, Screen
    Electrical - - December 1, 2019
    This picture shows a 12V plug that I added just inside the companionway, above the head door. There is a convenient, out of the way place in the corner in the corner of the head for the inside part of the plug. The wiring runs above the head door, th...
  • Rewiring
    Rewiring
    (A) is the power cables coming from the VHF and the compass. (B) is a bus bar that I glued onto the wall in the battery compartment. Wires run from the battery to this, and then to other circuits in the boat. I put a new heavier marine-grade cable fr...
  • Rewiring
    Rewiring
    No wiring other than the VHF power cords (I didn't do it) and a short wire from the fan are exposed in the interior. With patience, everything can be run through the conduits. All along the conduits are plastic hole covers from where the factory need...
