Interior Night Lighting
Published date: July 8, 2003
  • Boat Type: Boat Type
Because of problems seeing while underway when someone turns on the lights below decks, I made the following mod. It is two red Led lights, (West Marine #1202605) mounted in the ceiling of the boat. They are wired to a switch in the switch panel. Also the starboard light has a switch, which means if the port light is on you can turn on the starboad light or leave it off. The lights really help my night vision and draw very little battery power.
Published by: MS Classifieds
Model Year: 2003
Share
Related Mods
  • Anchor Light and Windvane
    Lighting - - December 1, 2019
  • Light In Head
    Light In Head
  • Light in the headroom
