Faucet
Published date: December 1, 2019
  • Boat Type: Boat Type
I highly suggest this relatively cheap modification! We added an electric faucet (small pump in-line) controlled at the faucet by a turn knob, not by a button. The button ones mean you have to hold the button down, where the knob one works just like your faucet at home. The faucet one is not terribly expensive, and it sure is better than hand pumping! My wife is much happier doing dishes now that she can run water into the sink easily.
Note - this faucet is available through West Marine.
Published by: MS Classifieds
Model Year: 1997
Share
Related Mods
  • Bilge pump
    Bilge pump
  • Water tank and deck fitting
  • Wash Down Pump System
    Water Systems - - September 5, 2017
    My slip is in a marina that does not provide water. Since it is a lake with relatively clean water, most folks at the marina do the old shool bucket method to wash their boats. That gets old really quick, and I wanted something better. After searchin...
