Steering Connector and Drainage Holes
Published date: December 1, 2019
  • Boat Type: Boat Type
This picture shows the custom-built connector from the steering system
to the engine. We started with a connector from the dealer, but it
didn't fit right. We had a welder build a new one, and it works
great! We leave the engine and rudders both connected to the steering
at all times.
To the sides you can see the compartments in the cockpit that can be
used to hold fuel tanks or batteries. We have the motor battery to
starboard and a single fuel tank to port. The problem was that the
compartments collected water. There were drainage holes in them, but
they were too far up the lip to drain much water, and it collected in
the bottom. I drilled new holes even with the bottom of the
compartments.
Published by: Heath
Model Year: 1997
Share
Related Mods
  • Gas Tanks - Installation & Draining
    Motor - - December 1, 2019
    Note gas tanks on either side - these were there when I bought the boat. I believe they are 9 gallon tanks. The past owner had do some minor cutting to the openings to get them in. From there, he cut holes in the seat, put those plastic screw plugs i...
  • Motor disconnect REMOTE
    Motor - - December 25, 2018
    The BWY quick Motor disconnect ist great!!! But it is quite bad to bring your head down to switch it on or off. Even worse if you have waves! So with the handle I can grab it from the cockpit, sitting on the helm seat! Worked great for 2 seasons now....
  • Outboard Motor Mount
    Motor - - July 9, 2017
    The previous owner of my 26D mounted the outboard to a retractable mount on the transom because he was a racer and wanted to make sure that the motor was completely out of the water. Unfortunately, wince I'm only 5'7", that put the outboard completel...
