Rear Speakers
Published date: December 1, 2019
  • Boat Type: Boat Type
We figured out a way to put speakers in the cockpit area (though my hat goes off to the guy that thought of mounting them in the pedestal, I hadn't thought of that). Our option was to use small box speakers (such as from Radio Shack) and screw a small handle to the top of them, so that they can then be hung from a webbing strap from the railing at the front of the cockpit. That way, you get both speakers pointing toward you, and therefore, good stereo separation. When we are done with them, we unclip them and bring them down below, which is nice because we then get even better sound down below (see front speaker modification). We have also glued the hook side of velcro to the bottom of the speaker so that when we set them on the seats or carpeting below, they stay in place. Note carpeting in the cockpit area - this is indoor/outdoor, with "dry-deck" (available from West Marine) under it to allow drainage.
Published by: MS Classifieds
Model Year: 1997
Share
Related Mods
  • Coachwhipping the helm
    Cockpit - steering (MacGregor 26M) - January 4, 2020
    I found that with such a small steering wheel I needed better grip so I took weeks of patience in coachwhipping it,
  • Cockpit Queen size bed
    Cockpit - - December 1, 2019
    Its usually too warm around Corpus Christi to sleep inside our cabin when we travel and anchor somewhere to sleep. The solution is simple. Mount six one inch strips of wood 6- ten inches long, which have had one edge rounded, to 3/4 of an inch below ...
  • Autohelm (Sort - of)
    Here's a real HIGH TECH autohelm.... Sometimes I am sailing alone, have the boat going straight & even, & want to go down below for a few minutes (or maybe just for a beer). I have put one of the little eye-straps below the steering wheel, and I run ...
