Winch Handle Pocket
Published date: December 1, 2019
  • Boat Type: Boat Type
See the attached where we placed a winch handle pocket. It is easy to find, and the pocket is always right where you need it (near the winches). Also note one of the doors that were constructed with the vent in the door. These are made of tinted plexiglass & allow us to see out the back when we stay on the boat, open one door easily while the sliding hatch is in place (great in a rain when we are down below.
Published by: MS Classifieds
Model Year: 1997
Share
Related Mods
  • Cork interior
    Cork interior
    Cockpit - (MacGregor 26X) - March 27, 2021
    Hi , for this decoration I used a 2mm thick cork roll and a slow-acting water-based glue.
  • Replace stuck steering wheel and Steering Brake
    Cockpit - 2002 (MacGregor 26X) - March 24, 2021
    Wanted to add a steering brake to my upgraded steering system. Had to use a 3 jaw puller to remove the old wheel. Tried wd40, pb blaster both overnight. 1. Used 24in breaker bar to remove the old wheel nut. Stabilize wheel. 2. Sprayed pb blaster and ...
  • Hatchway Doors
    Hatchway Doors
    Cockpit - (MacGregor 26X) - August 17, 2020
    As other owners have done, I've replaced the large white door that came with our '02 X. 3/4" plywood with 6 layers of spar urethane (the first 3 thinned 50% for absorption) and an oak piece for the overlap. Still need an inside latch or two when I fi...
