Autohelm (Sort - of)
Published date: December 1, 2019
  • Boat Type: Boat Type
Here's a real HIGH TECH autohelm.... Sometimes I am sailing alone, have the boat going straight & even, & want to go down below for a few minutes (or maybe just for a beer). I have put one of the little eye-straps below the steering wheel, and I run a bungee from there, around the bottom of the steering wheel a time or two, then back to the eye strap. Voila! - the wheel stays where I put it, and I am free to roam about the boat for a while.
Note the gas tanks on either side. That's the subject of another mod...
Published by: MS Classifieds
Model Year: 1997
Share
Related Mods
  • Cork interior
    Cork interior
    Cockpit - (MacGregor 26X) - March 27, 2021
    Hi , for this decoration I used a 2mm thick cork roll and a slow-acting water-based glue.
  • Replace stuck steering wheel and Steering Brake
    Cockpit - 2002 (MacGregor 26X) - March 24, 2021
    Wanted to add a steering brake to my upgraded steering system. Had to use a 3 jaw puller to remove the old wheel. Tried wd40, pb blaster both overnight. 1. Used 24in breaker bar to remove the old wheel nut. Stabilize wheel. 2. Sprayed pb blaster and ...
  • Hatchway Doors
    Hatchway Doors
    Cockpit - (MacGregor 26X) - August 17, 2020
    As other owners have done, I've replaced the large white door that came with our '02 X. 3/4" plywood with 6 layers of spar urethane (the first 3 thinned 50% for absorption) and an oak piece for the overlap. Still need an inside latch or two when I fi...
