Gas Tanks - Installation & Draining
Published date: December 1, 2019
  • Boat Type: Boat Type
Note gas tanks on either side - these were there when I bought the boat. I believe they are 9 gallon tanks. The past owner had do some minor cutting to the openings to get them in. From there, he cut holes in the seat, put those plastic screw plugs in (same as you would in a deck), and left the small space between the hole and the tanks open. I use a long funnel through the hole to fill the tanks. When gas runs low, I move the line from one tank to another, and know that it's getting time for a fill-up.
By the way, keep in mind that a nice long gas hose can be used to drain the tanks at the end of the season! I set it so the connection at the engine is held to the hose by means of a hose clamp. Then I run the hose out the back of the boat into another gas tank, take off the connection, then pump the bulb to get the hose acting as a siphon. Seems to work really well! This way I get rid of the old gas (use it in your car), and I can run the last of the gas out using an engine cooling system flusher. This keeps the carbs clean for the winter. This will really help avoid mechanic's costs, as bad gas causing gumming of the carbs is the primary cause of running problems. Keep in mind that gas stabilizer helps, but doesn't stop the problem. This is much better per a number of sites I have visted. Don't forget to fog the engine at the same time.
Published by: MS Classifieds
Model Year: 1997
Share
Related Mods
  • Steering Connector and Drainage Holes
    Motor - - December 1, 2019
    This picture shows the custom-built connector from the steering system to the engine. We started with a connector from the dealer, but it didn't fit right. We had a welder build a new one, and it works great! We leave the engine and rudders both conn...
  • Motor disconnect REMOTE
    Motor - - December 25, 2018
    The BWY quick Motor disconnect ist great!!! But it is quite bad to bring your head down to switch it on or off. Even worse if you have waves! So with the handle I can grab it from the cockpit, sitting on the helm seat! Worked great for 2 seasons now....
  • Outboard Motor Mount
    Motor - - July 9, 2017
    The previous owner of my 26D mounted the outboard to a retractable mount on the transom because he was a racer and wanted to make sure that the motor was completely out of the water. Unfortunately, wince I'm only 5'7", that put the outboard completel...
