Fire extinguisher
- Boat Type: Boat Type
A fire extinguisher found a good place between the headrom and the companionway. I placed it intentionally slightly off center: Something else will find its place there too. May be the winch handle with a better holder than the current quick-and-dirty solution.
Published by: MS Classifieds
Related Mods
Fire ExtinguishersSafety - - December 1, 2019
I mounted three fire extinguishers in our Mac 26X. I mounted a smaller model just behind the fore dining table seat against the starboard cabin wall in the v-berth area (see upper left part of graphic). I wanted one near the front hatch entrance/exit...
Ballast tank level LEDSafety - - January 17, 2018
Hello all I put a reed switch near the vent hole of the ballast tank. And a LED to show me that the tank is full. Works fine, had no problems so far, chaep, does not eat power... Also you can see the vent pipe. And still I can check with the finger i...
Mastreb Emergency Bilge PumpSafety - - May 10, 2015
I made a cheap emergency bilge pump based on Mastreb's idea from the following post: http://www.macgregorsailors.com/forum/viewtopic.php?f=8&t=23775&p=291105&hilit=Installing+a+bilge+pump#p291105 Actually, the Rule 2000 was rather expensive, so I wen...
