Anchor locker to mast raising and beyond.
Published date: March 1, 2005
  • Boat Type: Boat Type
The mods are applicable to many other sailboats, annotated photos make duplication easy. Consult http://community.webshots.com/user/griffinaero2
Published by: Bob Trail
Model Year: 2005
Share
Related Mods
  • Drainage Holes
    Drainage Holes
    Miscellaneous - - December 1, 2019
    Here you can see the new lower drainage holes I drilled in the battery and gas compartments. The caulking in the compartment also needed to be redone since it had a few leaks which brought water and gas into the space between the inner and outer shel...
  • Boat Cover
    Boat Cover
    The full boat cover protects the boat against the harsh Australian sun. Without the cover the fibreglass becomes oxidised quickly especially the black around the windows. The cover is easy to put on with a zipper from the mast to the bow. I can do it...
  • Motor Hoist
    Motor Hoist
    Miscellaneous - - June 14, 2006
    Being 70+ years old we had to find a better way to get dinghy motor off and onto the boat. We looked at many hoists and finally settled on the Garhauer Marine hoist. It is very good quality and reasonably priced. Mounting was a problem on the X, as i...
