Water tank and deck fitting
Published date: December 1, 2019
  • Boat Type: Boat Type
I replaced the starboard water tank with a better one (flexible type) which is now located below the cooler chest. The filling pipe goes below the headroom through the closet in the headroom and up on deck. You see the filling fitting on the picture. If you plan to do the same do not repeat my mistake: place the fitting more aft - right in front of the genoa sheet rail. Much easier to route the pipe.
Published by: MS Classifieds
Model Year: 1999
Share
Related Mods
  • Bilge pump
    Bilge pump
  • Faucet
    Faucet
  • Wash Down Pump System
    Water Systems - - September 5, 2017
    My slip is in a marina that does not provide water. Since it is a lake with relatively clean water, most folks at the marina do the old shool bucket method to wash their boats. That gets old really quick, and I wanted something better. After searchin...
