Transom Shower and Upgraded faucet
Published date: April 20, 2005
  • Boat Type: Boat Type
Put in a 40 PSI water system and upgraded the sink faucet. Also was able to put in a transom shower.
Published by: MS Classifieds
Model Year: 2005
Share
Related Mods
  • Bilge pump
    Bilge pump
  • Faucet
    Faucet
  • Water tank and deck fitting
