Anchor locker door
Published date: April 27, 2000
  • Boat Type: Boat Type
I borrowed this mod from Serge Lady V and it is an improvement from my previous method of getting rode to pass through the anchor locker door. The old method was to simply cut or grind out a hole for the rode to pass through. Now we have a larger section cut out and have it covered by a stainless steel vent cover. I think this looks much better.
The vent cover is from West Marine. Note that the original screw holes didn't work because of how the anchor locker door is constructed so I drilled new holes farther back on the vent cover.
Published by: Heath
Model Year: 1997
Share
Related Mods
  • Anchor roller
    Anchor roller
    Anchoring - - December 1, 2019
    I mounted the custom anchor roller from Blue Water Yachts on "Sea Breeze." Works great and was not too difficult to install. The bow light is relocated onto a special bracket on the anchor roller. I had to extend (actually I replaced) the wire supply...
  • Bow Plank
    Bow Plank
    Anchoring - - January 3, 2004
    Several months ago when sailing the Texas ICW I had to anchored many times..I found that under certain windy conditions the anchor rode would shift from side to side (port to starboard) and would catch on my running light and snap it off..I made a si...
  • Forward Cleat
    Forward Cleat
    I run a roller furling when I'm on extended cruises and when I day or weekend sail on the lakes I use a hank-on sail.....(Makes my set up time much faster).....Anyways, I found when the hank-on sail was lowered it covered my cleat and made it difficu...
